Visitor lpacphantom
Running ISE in Linux
I'm a fairly new user of Linux and I need to use the ISE for a class. I'm trying to run the program off a 16gb flash drive loaded with a full installation of Fedora 13.
I got the program installed fine in the default directory /opt/Xilinx/12.3/
Problem is now I can't launch the application. I feel incredibly stupid for not being able to locate the file the starts the ISE. I've searched a number of directories for something that resembles a shell script, but to no avail.
Any help is appreciated, thank you.
Re: Running ISE in Linux
You should see a directory ISE_DS under /opt/Xilinx/12.3/ . In /opt/Xilinx/12.3/ISE_DS, there are several settings32(64).(c)sh files. Source the one for your OS/Shell. e.g. if you use C-shell on a 64-bit machine, run
source settings64.csh
which sets the environment for running all IDS tools.
Below are several useful commands you may want to take a note:
ise            - Project Navigator
xps            - EDK Platform Studio
planAhead      - PlanAhead
fpga_editor    - FPGA editor
coregen        - Core Generator
timingan       - Timing Analyzer
smartxplorer   - SmartXplorer
sysgen         - System Generator
analyzer       - Chipscope Analyzer
Cheers,
Jim
Cheers,
Jim
Visitor lpacphantom
I believe my shell is bash, and it's a 32 bit install. My IDE_DS directory has these:
common  EDK  ISE  PlanAhead  readme.txt  settings32.csh  settings32.sh
I've tried running the command:
source settings32.sh
but nothing happens. I'm used to running the Project Navigator on Windows, and I expect to get much the same GUI in Linux. Am I right about that?
"source settings32.sh" only sets up the environement (i.e. necessary environment variables, PATH to IDS commands, etc). You need to run the actual command to start the tool: From the same terminal your sourced settings32.sh, run
ise
which will start Project Navigator.
Cheers,
Jim
Visitor lpacphantom
Ok, that makes sense. It still does nothing useful though. SELinux logs errors each time. It recommends commands to fix it, but it just leads me around in circles. Any ideas? I've tried su and running it as root to no avail.
Error summary:
Summary:
SELinux is preventing /opt/Xilinx/12.3/ISE_DS/ISE/bin/lin/ise from loading
/opt/Xilinx/12.3/ISE_DS/ISE/lib/lin/libMiniZip.so which requires text
relocation.
Detailed Description:
The ise application attempted to load
relocation. This is a potential security problem. Most libraries do not need
this permission. Libraries are sometimes coded incorrectly and request this
permission. The SELinux Memory Protection Tests
(http://www.akkadia.org/drepper/selinux-mem.html) web page explains how to
remove this requirement. You can configure SELinux temporarily to allow
/opt/Xilinx/12.3/ISE_DS/ISE/lib/lin/libMiniZip.so to use relocation as a
workaround, until the library is fixed. Please file a bug report.
Allowing Access:
If you trust /opt/Xilinx/12.3/ISE_DS/ISE/lib/lin/libMiniZip.so to run correctly,
you can change the file context to textrel_shlib_t. "chcon -t textrel_shlib_t
'/opt/Xilinx/12.3/ISE_DS/ISE/lib/lin/libMiniZip.so'" You must also change the
default file context files on the system in order to preserve them even on a
full relabel. "semanage fcontext -a -t textrel_shlib_t
Fix Command:
chcon -t textrel_shlib_t '/opt/Xilinx/12.3/ISE_DS/ISE/lib/lin/libMiniZip.so'
Edit: I just ran the installation again and read the final page where it describes sourcing the settings files. My bad on missing that the first time. But the issue remains: I can't launch the ISE.
Sorry I am not very familiar with SELinux, so I can't be of too much help on that. Having said that, I normally disable SELinux. (Disclaimer: I'm NOT suggesting you do one way or the other. You will need to make your own decision and proceed at your own risk).
Cheers,
Jim
Visitor lpacphantom
Thanks for you help Jim. I'll keep looking into my options, I'll get it working eventually.
i also was trying to use ISE (12.3) on a linux system but without any succes to start it.
This Topic helped me with the source settings32.ch issue but after i also couldn't start the ISE software.
I found on a ubuntu forum something that helped to launch the ISE.
In the terminal i had to go to the following place:
/opt/Xilinx/12.3/ISE_DS/bin/lin
Then run following command:  ./ise
And the ise software came up.
Maybe that's your solution too? :)
Mark
Visitor lpacphantom
I've had success with both the methods provided. I ended up having to disable SELinux and chmod-ing the opt directory to make it easier to use. For some reason, sourcing the settings file only worked on my normal desktop which is running 64-bit Fedora. However, using ./ise in /opt/.../bin/lin/ worked on my flash drive (which has been upgraded to a 32gb drive due to a memory error while trying to install on the 16gb) Thank you for all your help.
Newbie zt1
Hi Mark,
I managed to get ISE running using your advice. Just to clarify that the bin folder is in the ISE folder in ISE_DS, and not in ISE_DS itself.
Newbie xbartek
Full path to Xilinx ISE
/opt/Xilinx/13.3/ISE_DS/ISE/bin/lin/ise
For 100% it'll be working :)
B. Ojmuciański
