afonsofc
SDK does not edit files - ISE 10.1 on Fedora 12
I have installed ISE 10.1 sp 3 on Fedora 12.
When I create a SDK project, the default main.c file comes blank and it is not editable. If I create a new file it is also not possible to edit it.  The problem seems related to eclipse.
If I call eclipse outside EDK I have the following error:
 [fafonso@Desktop lin]$ ./eclipse
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00db65d9, pid=2674, tid=2442046320
# JRE version: 6.0_17-b17
# Java VM: OpenJDK Client VM (14.0-b16 mixed mode linux-x86 )
# Derivative: IcedTea6 1.7.1
# Distribution: Custom build (Fri Mar 12 08:29:38 EST 2010)
# Problematic frame:
# V  [libjvm.so+0x1e65d9]
# An error report file with more information is saved as:
# /home/fafonso/Xilinx/EDK/eclipse/bin/lin/hs_err_pid2674.log
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
#   http://icedtea.classpath.org/bugzilla
I have installed everything again and the problem continues.
Any help?
