SDK fails to launch from Vivado 2016.4 Windows 7 x64 and directly from xsdk.bat
Accepted Solution Solved
Accepted Solution
It has been working for several months. Yesterday windows updated and forced a reboot while the SDK was open. Today I cannot even get to the main SDK screen. The log says:
!SESSION 2017-06-15 18:22:25.842 -----------------------------------------------
eclipse.buildId=2016.4
java.version=1.8.0_66
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2017-06-15 18:22:26.679
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: org.eclipse.swt.internal.win32.OS.WNDCLASS_sizeof()I
at org.eclipse.swt.internal.win32.OS.WNDCLASS_sizeof(Native Method)
at org.eclipse.swt.internal.win32.WNDCLASS.<clinit>(WNDCLASS.java:31)
at org.eclipse.swt.widgets.Display.init(Display.java:2742)
at org.eclipse.swt.graphics.Device.<init>(Device.java:138)
at org.eclipse.swt.widgets.Display.<init>(Display.java:489)
at org.eclipse.swt.widgets.Display.<init>(Display.java:480)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:750)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:162)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:169)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:111)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Any clue?
Thanks!
Re: SDK fails to launch from Vivado 2016.4 Windows 7 x64 and directly from xsdk.bat
@ubenevides
Can you try adding the SDK executable location to PATH environment variable?
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).
All Replies
@ubenevides
Nupur
