Segmentation Fault Error when starting Vivado v2015.2 (64-bit)
I installed Vivado v2015.2 (64-bit) in CentOS 7.
However, Vivado tool is disappeared in a second with the following error message.
   /opt/Xilinx/Vivado/2015.2/bin/loader: line 157: 3687 Segmentation fault (core dumped) "$RDI_PROG" "$@"
Please, let me know what I have to do.
Chorong Kim
Re: Segmentation Fault Error when starting Vivado v2015.2 (64-bit)
Hi @polaris042
I still observe that the environmental variable GNOME_DESKTOP_SESSION_ID is set. Can you try unsetting it?
Vinay
Hi @polaris042
unset the environmental variable GNOME_DESKTOP_SESSION_ID and try?
Vinay
Yes, I tried it but it doesn't worked.
Hmm.. what is the result after 'unset GNOME_DESKTOP_SESSION_ID' ?
When I tried 'echo $GNOME_DESKTOP_SESSION_ID' after that, I got 'this-is-depreated'.
Is it a correct result?
Chorong Kim
Hi @polaris042
Share the output of the command: env
Vinay
You may open with new project inplace of current project.
The current project may be the root cause of this issue
Thanks and Regards
Balkrishan
I make a new user account and try again, but the same error is reported.
I attatched env.log file. Please, check it.
Chorong Kim
What is returned by:
ldd /opt/Xilinx/Vivado/2015.2/bin/unwrapped/lnx64.o/vivado
See if any "not found" libraries are available under the 2015.2/lib/lnx64.0/ directory.
Daniel
I got the following report.
linux-vdso.so.1 => (0x00007ffec71cf000)
libtcmalloc.so.4 => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libtcmalloc.so.4 (0x00007fe6afb02000)
libboost_signals.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_signals.so (0x00007fe6af8eb000)
librdi_common.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdi_common.so (0x00007fe6aed38000)
librdi_commonmain.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdi_commonmain.so (0x00007fe6aeb2c000)
libstdc++.so.6 => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libstdc++.so.6 (0x00007fe6ae829000)
libgcc_s.so.1 => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libgcc_s.so.1 (0x00007fe6ae613000)
libc.so.6 => /lib64/libc.so.6 (0x00007fe6ae23f000)
libm.so.6 => /lib64/libm.so.6 (0x00007fe6adf3c000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fe6add20000)
libCOIN-all.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libCOIN-all.so (0x00007fe6ad650000)
libXil_lmgr11.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libXil_lmgr11.so (0x00007fe6ad2e8000)
libboost_date_time.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_date_time.so (0x00007fe6ad0d8000)
libboost_filesystem.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_filesystem.so (0x00007fe6acec2000)
libboost_program_options.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_program_options.so (0x00007fe6acc52000)
libboost_regex.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_regex.so (0x00007fe6ac96c000)
libboost_system.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_system.so (0x00007fe6ac769000)
libboost_thread.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_thread.so (0x00007fe6ac549000)
libhdlpsolve.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libhdlpsolve.so (0x00007fe6ac2a6000)
libhdxml.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libhdxml.so (0x00007fe6abffc000)
libisl_iostreams.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libisl_iostreams.so (0x00007fe6ab7c3000)
libisl_iosutils.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libisl_iosutils.so (0x00007fe6ab5aa000)
libisl_sysinfo.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libisl_sysinfo.so (0x00007fe6ab377000)
libprotobuf.so.7 => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libprotobuf.so.7 (0x00007fe6ab085000)
librdi_commonxillic.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdi_commonxillic.so (0x00007fe6aae25000)
librdi_curl.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdi_curl.so (0x00007fe6aaa16000)
librdiconfig.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdiconfig.so (0x00007fe6aa7fd000)
librdizlib.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdizlib.so (0x00007fe6aa5d7000)
libtcl8.5.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libtcl8.5.so (0x00007fe6aa2b5000)
libxerces-c-3.1.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libxerces-c-3.1.so (0x00007fe6a9d0a000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fe6a9b06000)
libgomp.so.1 => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libgomp.so.1 (0x00007fe6a98f8000)
librdi_commonversion.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/librdi_commonversion.so (0x00007fe6a96f4000)
/lib64/ld-linux-x86-64.so.2 (0x00007fe6afd75000)
librt.so.1 => /lib64/librt.so.1 (0x00007fe6a94ec000)
libboost_iostreams.so => /opt/Xilinx/Vivado/2015.2/lib/lnx64.o/libboost_iostreams.so (0x00007fe6a92d8000)
OK, it does not appear you are missing any libraries.
Next thought is to run:
strace -f vivado -o /tmp/vivado.strace.out
That will show you what system calls are made just before the program crashes.
Hi @polaris042
Vinay
It works!
I used wrong a command for unsetting GNOME_DESKTOP_SESSION_ID variable.
I should 'unsetenv' command instead of 'unset' because I use c-shell environment.
Thank you for your supports!
Chorong Kim
I stumbled across this forum post which shows a workaround for unsetting the environment variable GNOME_DESKTOP_SESSION_ID.
I confirmed that this workaround indeed does work and if you add the following command to your .bashrc file, you won’t need to run the command each time you restart your machine.
That information came from this thread here:
http://stackoverflow.com/questions/21261616/ubuntu-13-04-gnome-desktop-session-id
Hopefully this thread helps if you ever run into this issue while setting up Vivado Design Suite 2015.2.1 under Desktop Linux using CentOS 7 (with both the 1406 and 1503 releases).  It certainly helped me!
-Kevin
I get basically the same error. on 2018.2.
Nice to see they have made a lot of improvements to the product since.
My line number is different.
Vivado-2018-2/SDK/2018.2/bin/loader: line 194: 4530 Segmentation Fault (core dumped) "sRDI_PROG" "$@"
Yes, I am on a supported OS.
I have been building code and designs with this installation for over a year.
One day it just up and does this because of something that broke.
If you don't see any other replies, start a new topic.  Old topics are often not monitored (and I do not have anything to add).
Daniel
I have something to add...
I went into the SDK project .metadata directory and removed the .lock file and now the error is gone.
Your welcome!
