travbeav
Single OS Vivado download?
Where can I find a single OS (Linux) download for Vivado 2016.1?  The system I am installing this on has no internet access, so I need to pull down the full install, but I do not need the "all OS" 11GB file.
vuppala
Hi @travbeav
I suggest you to download web installer (Snapshot below) and select the option "Download Full Image (Install Separately)".
This procedure will help you to download Linux only Vivado tool to install it on other machines (no internet access).
Vinay
syedz
@travbeav,
From Vivado 2016.1 there is only one single All OS image file for Windows and Linux. You can download the file from the below AR
http://www.xilinx.com/support/answers/67021.html
--Syed
vuppala
Hi @travbeav
Vinay
giteshsk
I got the image in a dir using "install vivado download Full image ( Install separately)", how to install now? Not able to find installer in the dir structure.
