skoxilinx
Spartan IIE programming in Windows 10
The company currently has a product with a Spartan IIE inside. We program it via a batch file calling commands from ISE 10.1 on an XP computer. The XP computer is now being changed to Windows 10. Is there a replacement for ISE10.1 which runs on Windows 10 and programs the Spartan IIE, the latest version only seems to do Spartan 6?
bpatil
Hi @skoxilinx,
Last ISE version that supports Spartan IIE is ISE10.1.03i.
You can install ISE 10.1 in windows 10. Steps are provided at https://www.xilinx.com/support/answers/62380.html
Bhushan
Bhushan
bpatil
Hi @skoxilinx,
Bhushan
Bhushan
skoxilinx
Thank you so much Bhushan for you fast reply I shall try this over the weekend
Steve
skoxilinx
I have tried your suggestion and the software installed without any problem. Unfortunately when I try to us a Xilinx Platform Cable USB II it comes up with the following error
"WARNING:iMPACT:923 - Can not find cable, check cable setup"
Am I missing something in the install?
Steve
bpatil
Hi @skoxilinx
In Device manager check for drivers for platform cable USB II installed correctly or not?
Check following link to resolve your problem: https://forums.xilinx.com/t5/Configuration/Platform-cable-usb-II-driver-for-windows-10/td-p/699459
Bhushan
Bhushan
skoxilinx
Hi Bhushan
Thank you ones again for your fast response, I have looked at the drivers and they seem OK. As none of this software is supported on windows 10 I am going to get the company to consider it a legacy product and keep the XP machine for programming Spartan IIe devices. As the machine is not networked I don’t see his as an issue. Thanks ones again for your help.
Steve
