Standalone Impact - without Vivado 2015.x
How can I get a standalone Impact cabable of programming Virtex7 without installing the Vivado 2015.x Webpack?
Currently I use 2015.2 under Ubuntu 14.
Is there an easy way to get only this Hardware programming part?
Background: the FPGA card is located in a server, several users access it, but the FPGA compile occurs elsewhere, so absolutely no need for the several GBytes to be wasted on Vivado.
As a work around can I use older Impact versions to program a new Virtex7 chip?
  Andras
Re: Standalone Impact - without Vivado 2015.x
Hi @csuziandras,
Download the Hardware server tools from this link:
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-2.html
If you need logic/serial IO debug, you can download the Vivado Lab Edition Tools.
These files are smaller in size.
Accept as solution if it resolved your query, give kudos if post is helpful
Nupur
Hi @csuziandras,
Nupur
thanks, I tried to install it.
I got an error message:
./xsetup: /home/acsuzi/Downloads/Xilinx_HW_Server_Lin_2015.2_0626_1/tps/lnx32/jre/bin/java: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
my OS is 64bit, which is also checked in this xsetup script:
# ERROR out if this installation is running on 32 bit OS # and does not support 32 bit installation if [ "$(uname -i)" != "x86_64" ]; then
(This maybe irrelevant, I dont know)
But the Java file that the downloaded installer contains seems to be 32-bit version:
   ./Xilinx_HW_Server_Lin_2015.2_0626_1/tps/lnx32/jre/bin/java
Do you have any suggestions how to procced with the install?
Thx,
  Andras
Hi @csuziandras,
Are you using Ubuntu 14.04? That is the only supported version I think.
Check page 9 of this link for supported OS: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf
Nupur
Hope the information in below Answer Records are also useful for you
http://www.xilinx.com/support/answers/54242.html
http://www.xilinx.com/support/answers/64638.html
http://www.xilinx.com/support/answers/64361.html
http://www.xilinx.com/support/answers/63890.html
@nupurs:
No, I was mistaken. On this particular server we have Fedora23.
We figured out the issue, we simply installed open-jdk for i686, so that we have the missing 32-bit packages.
Then the installer succeeded.
HI @csuziandras,
Glad to know that the issue is resolved. So please close this thread by marking appropriate reply as solution in the interest of other users.
Nupur
hi,
I have closed the issue, thx for the support.
one more thought:
run the hw_server as root, otherwise the remote connection does not work, and the app does not give any warning about the lack of root rights....
Andras
