50081647
Supported Devices of the ModelSim XE-III Free Edition
hello, I have installed ise webpack 9.2I and I need the license file "license.dat" for MXE III EDITION software MODELSIM someone has ?. send it to me to fgapfgap@gmail.com. Thank you.
balkris
check ISE classic versions
http://www.xilinx.com/tools/classics.htm
Thanks and Regards
Balkrishan
50081647
Hello, I just need the Archicad "lecense.dat to work ModelSim MXE III. I Temgo Toso software but not that file.
gszakacs
Professor
Professor
It is my understanding that Xilinx cannot issue any new licenses for ModelSim XE and that there was a Discontinuance Notice regarding this.  You didn't mention what devices you are working with.  ISE 10.1 supports all of the devices available in 9.x and comes with ISIM simulator.  If you are not using very old devices like Virtex II or Spartan 2, then you can upgrade to ISE 14.7, which comes with a much improved version of ISIM.
-- Gabor
50081647
Hello, I am using a TAD-XC9572 Blast of Abratelecom (http://todoelectrodo.blogspot.com.es/2012/12/proceso-de-descarga-en-cpld-xc9572.html) with ISE webpack 9_2_03i_win and modelsim MXE III need the "license.dat" file to run.thanks
