Sysgen license checkout failed with floating licence problem
I installed Vivado 2018.2 with a floating licence. I attached the VLM window and I can see all licences (at least I hope). 
Nevertheless, when I build an FPGA project from Matlab 2018a, I receive the following error:
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 2018.2 C:/Xilinx/Vivado/2018.2
Matlab 9.4.0.813654 (R2018a) C:\Program Files\MATLAB\R2018a
Vivado 2018.2 C:/Xilinx/Vivado/2018.2
Summary of Errors:
Error 0001: Sysgen license checkout failed.
XILINXD_LICENSE_FILE = 2...
Block: Unspecified
Error 0001:
Reported by:
Unspecified
Details:
XILINXD_LICENSE_FILE = 2100@svrmicro.dei.unipd.it;C:/Xilinx/Vivado/2018.2/data/sysgen/hwcosim_compiler/pp_ethernet
LM_LICENSE_FILE = Xilinx.lic
License search path: C:\Users\ludovico.ortombina\AppData\Roaming\XilinxLicense;C:\.Xilinx;2100@svrmicro.dei.unipd.it;C:\Xilinx\Vivado\2018.2\data\sysgen\hwcosim_compiler\pp_ethernet;Xilinx.lic;C:\Xilinx\Vivado\2018.2\data\ipcore_licenses
and it seems that it cannot find the sysgen licence despite I can see it in VLM window.
Do you know how to solve with this problem or what is it due to?
Thank you,
Best regards, Ludovico
ansarimo
Hi @LudovicoOrtombi ,
From the shared snapshot of VLM, I see that you have a license for the SysGen feature, check if its license CRC is okay to be used and confirm on this?
Please check if you are using the supported OS for Vivado 2018.2 and also, let me know the same.
Run the below command to make sure the license server is up and running, also share the snapshot of it:
lmutil lmstat -a -c port@server
If your license server is up and running then make sure to set the only XILINXD_LICENSE_FILE environment variable, the license file which is serving the floating server should not be pointed directly from VLM as it is already being served to the floating server, in this cases tools get confused which license to be used.
If still issue persists then share the following files to check this issue:
  1. The complete license file(xilinx.lic).
  2. Run the below command from Vivado TCL console and share the generated xinfo.txt file, run pwd to know the location if this file.
report_environment -file xinfo.txt
Thanks & Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
ansarimo
Thanks & Regards,
Ansari Hunen
anatoli
Hello @LudovicoOrtombi ,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
However if your issue is resolved now, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
