Unable to start Vivado in Ubuntu
I had installed Vivado 2015.3 on my Ubuntu system following the guidelines in the attached PDF. While running Synthesis, memory got exhausted and I decided to restart the system. After restarting, I am trying to invoke Vivado from the bash command prompt but it does not start.
The command prompt looks like this:
sudo vivado &
[3] 3355
I am trying to open Vivado in the same path where my top level design (.vhd) file is residing.
Please help.
Re: Unable to start Vivado in Ubuntu
Sorry, I had to source the script before starting, its working now.
source /opt/Xilinx/Vivado/2015.3/settings64.sh
Please check whether the information in the below Answer records help to get any debug clue
http://www.xilinx.com/support/answers/62240.html
http://www.xilinx.com/support/answers/62241.html
http://www.xilinx.com/support/answers/63098.html
