ariel_serafim
Uninstall vivado 2019.1 from ubuntu 18.04
I'm trying to remove vivado 2019.1 from my ubuntu 18.04. I tried the command "sudo ./xsetup -Uninstall" to remove it, but I get the message "sudo: ./xsetup: command not found". I also tried to use sudo apt remove “package-name”, but dpkg --list | grep vivado gets no return.
anatoli
Hello @ariel_serafim ,
When you run a command using sudo, you are effectively running it as the superuser or root.
The reason that the root user is not finding your command is likely that the PATH environment variable for root does not include the directory where xsetup is located. Hence the command is not found.
Please use the command provided by @graces and this should allow you to begin the uninstall process.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
watari
Hi @ariel_serafim
WOuld you try the following command ?
sudo bash ./Xsetup -Uninstall
ariel_serafim
I get the following line as a return: bash: ./Xsetup: No such file or directory
watari
Hi @ariel_serafim
Would you change installed directory before running it ?
ariel_serafim
change to which directory?
watari
Hi @ariel_serafim
Your installed directory.
ex)
Here is my installed directory.
/opt/Vivado/2019.2
So, I must change current directory to /opt/Vivado/2019.2
Best regards
graces
Here's the command line to uninstall.
<install_path>/.xinstall/Vivado_2019.1/xsetup –uninstall
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
anatoli
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
dyessgg
I too have the problem of needing to uninstall Vivado.  I used the command you gave and it appeared to go through the motions but nothing was done. Files were not removed and the GNOME Menu group items were still installed.
Doing a little checking, the correct option should be "-b uninstall" instead of "--uninstall".
