gvirbila
Unsupported Architecture
I have recently purchased the Kintex-7 FPGA KC705. I have redeemed the voucher and when setting up the design properties, I am unable to find XC7K325T FPGA. Does anyone know how to resolve this issue? Thanks.
graces
Make sure you didn't select WebPACK when you installed Vivado. Otherwise you are only able to see WebPACK devices.
syedz
can you post license and Xinfo file?
To  run XINFO:
Open a command shell and CD to the <install Dir>\Vivado\2013.2\ids_lite\ISE\bin\nt64 directory. Then type xinfo
Alternatively, on Windows platforms, browse to the directory in an explorer window and double click on the executable “xinfo.exe”.
Syed
gvirbila
Here is the xinfo. Thanks.
syedz
Looks like tool is picking up Webpack license which only supports two devices of Kintex 7 family  which are highlighted below:
Can you also post the License file(.lic) generated with the voucher?
Syed
gvirbila
Here is the .lic file. Thanks
graces
