tmeyerngc
Unzip of Training Materials Fails
Hi-
A while back, I took the Essentials of FPGA Design class, but didn't need the info until recently.  To refresh my memory, I downloaded  the file fpga-vess-2015.3-rev1-xlnx_lab_files.7z from the Xilinx website in order to do the associated labs.
Whenever I try to unzip the file, it halts after a few seconds with a message saying "Winzip encountered problems during this operation".  If I look at the log, many files seem to be unzipped correctly, but the last entry says;
Cannot create C:<my_user_directory>\XilinxLabs\Essentials\training\essentials\completed\IP_Integrator\KCU105\vhdl\UART_LED_Subsystem\UART_LED_Subsystem.srcs\sources_1\bd\UART_LED_Subsystem\ip\UART_LED_Subsystem_meta_harden_0_0\synth\UART_LED_Subsystem_meta_harden_0_0.vhd
Irrecoverable Error: Extract operation failed.
I've tried repeating the download, but always get the same error.
My computer is running Windows 7 (64 bit) and the version of WinZip that launches is WinZip 22.0 Enterprice (12633) -64 Bit
Any suggestions?
Thanks for any assistance you can provide.
tedbooth
I notice that the archived file has a "7z" (7 zip) extension.  Have you tried using 7-zip to decompress it?
https://www.7-zip.org/
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
tedbooth
tmeyerngc
Thank you!  That worked.
anatoli
Hello @tmeyerngc,
Thanks a lot for letting us know and we are glad to see your issue is resolved now.
As your issue is solved, please mark an appropriate response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so  the topic can be completed then. We appreciate your help.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
