Update Vivado and SDK to 2018.2.2
Does exist some reliable method to update Vivado (i.e. run some command from Tcl console or something like that) ?
I've tried to download update 2018.2.2 two times from Xilinx update page and two times downloading was interrupted.
Re: Update Vivado and SDK to 2018.2.2
Hi @pavel_47,
You can try by updating it from Xilinx Information Center.
Else what error you facing while updating?
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @pavel_47,
hemangd
hemangd
It works. Thanks !
