pavel_47
Voyager
Voyager
Update Vivado and SDK to 2018.2.2
Does exist some reliable method to update Vivado (i.e. run some command from Tcl console or something like that) ?
I've tried to download update 2018.2.2 two times from Xilinx update page and two times downloading was interrupted.
hemangd
Hi @pavel_47,
You can try by updating it from Xilinx Information Center.
Else what error you facing while updating?
hemangd
hemangd
hemangd
Hi @pavel_47,
hemangd
hemangd
pavel_47
Voyager
Voyager
It works. Thanks !
