msj007
Upgrading Vivado Webpack to Design Edition to add ZC706
I have installed Vivado webpack (2020.2) on my PC. But I need to synthesize a previous project which was done using ZC706 which needs the design edition. I opened the License Manager and obtained license for option 'Get Vivado or IP Evaluation License' for a 30 day license. I can see that license being listed in my licenses. Does this mean that I have the design edition now? Or should I explicitly uninstall and reinstall Vivado with design edition selected?
I have downloaded the board files for zc706 using xHub Stores and I can see the board files in 'C:\Xilinx\Vivado\2020.2\data\boards\board_store'. I even tried copying the zc706 board files (zc706 folder) to 'C:\Xilinx\Vivado\2020.2\data\boards\board_files'. However I cannot find the board in the board selection page when I start a new project. Can you please help me with this issue?
hpbhat
Yes, As per my experience, you have to re-install Vivado with Design edition. Manually copying  board_files has no effect.
With Regards,
HP Bhat
hpbhat
With Regards,
HP Bhat
anatoli
Hello @msj007 ,
Have you tried upgrading using Add Design Tools or Devices 2020.x?
I haven't done Vivado WebPACK installation for long time and don't know if we have now implemented the upgrade of the edition via Add Design Tools or Devices 2020.x, however you can give this a try and see if this allows you to update your current Vivado edition from Vivado WebPACK to e.g. System Edition?
If that doesn't allow you to do the update, then yes, as already indicated by @hpbhat , you'd need to uninstall Vivado WebPACK edition (to save disk space) and re-install Vivado, selecting Vivado Design or System Edition this time. FYI - System Edition is Vivado Design Edition (with support of all of the devices) + SysGen. So, if you don't need SysGen, then Design Edition is all you need in this case.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
msj007
thank you for the answer, I updated it by using the 'add design tools and devices' as mentioned by @anatoli
