VCU118 Bitstream generation for AXI Ethernet Subsystem is not perimited
Hi all,
We recently brought a VCU118 board and have installed a "Virtex Ulrascale+ FPGA VCU118 Vivado Design Edition Device Locked License" by using the voucher code within the kit
When I tried to generate the bitstream of the example design for AXI Ethernet Subsystem, vivado gave an error:
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
axi_ethernet_0_support/U0_axi_ethernet_0/inst/mac/inst/bd_5d9f_0_mac_0_core (bd_5d9f_0_mac_0_tri_mode_ethernet_mac_v9_0_9)
If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation.
Here is my license status:2.PNG
I want to ask if I need to order an additional license in order to generate the bitstream for projects that include a AXI Ethernet Subsystem:)
Thanks a lot!
Re: VCU118 Bitstream generation for AXI Ethernet Subsystem is not perimited
You required to buy separate license . This IP not bundled freely  with Vivado Tools
Check here part number and license requirement
https://www.xilinx.com/products/intellectual-property/temac-software-requirements.html
You can also use full hardware evaluation license for this IP
Hardware Evaluation Time Out Period * : ~ 1-8 hrs . Thats mean when you configure IP will work for few hours and again you need to configure after evaluation time
Thanks and Regards
Balkrishan
@kleinkuang
Refer this AR:
https://www.xilinx.com/support/answers/58758.html
If this didn't help share the license and xinfo file. Xinfo can be generated by running the below command in the tcl console:
report_environment -file <file_path>env.txt
Rohit
Rohit
Thanks and Regards
Balkrishan
