Valid license not found
we purchased a nodelocked license with version limit 2018.01
Expiration date is permanent.
I installed vivado 2017.3 but synthesis failed because no valid license was found.
In AR 33770 it says:
"The license will enable any version of the design tools released during or before the month specified by the Version Limit"
So i should be able to use vivado 2017.3 with current license. What is the problem?
Re: Valid license not found
Just to post the finding to this problem, in case someone else will encounter the same issue.
If your flexnet dongle is an older HASP4 dongle and not a newer HASP HL dongle, then Vivado 2017.3 won't be able to detect this dongle and to check out the license file. Please note that the HASP4 dongle should work fine with any previous versions of Vivado upto and including Vivado 2017.2, but not with Vivado 2017.3 and the newer releases.
The recommendation here is to replace HASP4 dongles with newer HASP HL dongles.
To verify if your dongle is a HASP4 dongle or a newer HASP HL dongle, please open your Device Manager -> USB Controller, and in here check and see if you have e.g. "Sentinel HASP Key", "Sentinel HL Key" and "Sentinel USB Key". If that is the case, then your dongle is a HASP HL dongle, however if in your case "Sentinel HL Key" is missing, that is an indication that you are most likely using an older version of a dongle, which is a HASP4 dongle and it won't work with Vivado 2017.3.
Therefore, in case  you are using a HASP4 dongle, and if you are working with Vivado 2017.3, then the option you have in this situation is either order a new HASP HL dongle so that you can use this with the newer tools, or just re-generate your license to target your NIC ID (Network Interface Card ID) or a DISK_SERIAL_NUM instead of your dongle’s ID.
Hope this helps.
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
@sevenclock
Yes, you should be able to use 2017.3 with version limit of 2018.1. Have you generated the license for the correct host id?
Can you share the license and the Xinfo file? Xinfo can be generated by running the below command in the tcl console.
report_environment -file <file_path>env.txt.
Also share the screen shot of the VLM (Vivado license manager) Go to Help-->Manage license in the Vivado IDE for this.
Rohit
Rohit
Hello @sevenclock,
Please open Vivado License Manager (VLM) and under "Manage License Search Paths", point your XILINXD_LICENSE_FILE to the location where you have saved your Node-Locked license in.
Then, in VLM, under "View License Status", check and see if your license being listed in the table? If so, do you see "Host ID Matches" shows YES for this license or NO? Can you confirm on this please?
Anatoli
Kind Regards,
Anatoli Curran,
@thakurr
Hi Rohit,
find attached a part of the report_environment file
Hi @sevenclock
The half env.txt file you shared says host id of your machine and host id for which license was generated doesnot match. Host Id Matches column says no.
Hence please generate the license for the host id of your machine. You can follow the steps mentioned in this link to rehost the license:
https://www.xilinx.com/support/answers/36136.html
Rohit
Rohit
Hi @thakurr
I run the aforementioned tcl command in vivado 2017.1 on my machine and the host id matches "yes"...
Hello @sevenclock,
Is your Flexnet Dongle is detected correctly on this machine? Is the Red light ON?
Can you please open a command prompt and CD to the location such as: C:\Xilinx\Vivado\2017.3\bin\unwrapped\win64.o and from here please run this command: lmutil lmhostid -flexid
Do you get your Flex ID populated here? Or do you see "" instead (so no value populated)?
Anatoli
Kind Regards,
Anatoli Curran,
Hi @sevenclock
This is an issue with host id as i pointed out before. I am not sure why same license show host id yes in 2017.1. Can you share the complete Xinfo file  and the license file?
Between i would still suggest you to generate the license for correct host id to get rid of the issue.
Rohit
Rohit
Hi @anatoli
The Flex ID is not populated! -> ""
Hi again @sevenclock,
Can you please confirm if you are intended generated this license to target a dongle's HOST ID, and if so, do you have a valid dongle? If so, if you plug in the dongle into your PC, do you see a Red light on this dongle? That would indicate if the dongle's drivers were installed correctly or not.
Anatoli
Kind Regards,
Anatoli Curran,
Hello @sevenclock,
I know where there issue is coming from. As you are working with Vivado 2017.3, you'd need to follow the steps in the below AR to get your dongle detected correctly. Please follow these steps and you'd then be able to overcome this issue.
https://www.xilinx.com/support/answers/47132.html
After following these steps, make sure you've copied both haspsrm_win64.dll together with haspsrm_win32.dll files to %windir%/System32 (e.g. C:\Windows\System32) and also to the %windir%/SysWOW64 locations (e.g. C:\Windows\SysWOW64)? Please note that both libraries (_win64.dll and win32.dll) need to be copied into these 2 locations.
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
the solution does not work for me.
Host Id Matches -> "No"
Hello @sevenclock,
Is the dongle still not detected (i.e. no red light is on when you plug in the dongle into the PC)?
Have you actually copied both haspsrm_win64.dll together with haspsrm_win32.dll files to %windir%/System32 (e.g. C:\Windows\System32) and also to the %windir%/SysWOW64 locations (e.g. C:\Windows\SysWOW64)?
Can you confirm on this please? Thanks
-Anatoli
Kind Regards,
Anatoli Curran,
@sevenclock, also if the dongle is inserted into the machine and the red light on the dongle is ON, if you run this command: lmutil lmhostid -flexid, do you still see your Flex ID populated as "" instead of an actual number of the dongle?
Kind Regards,
Anatoli Curran,
Hi @anatoli
I forgot to mention that the dongle is on a remote dongleserver(remote pc).
Hi @sevenclock
In this case please regenerate your license targetting your nic id of the machine where you're trying to work with Vivado 2017.3, instead of using the dongles hostid, as the dongles hostid isn't detectable on your machine and that's causing the licensing issue.
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli,
I plugged the flexid usb device directly on my machine and run the "lmutil -flexid" and the flex id is populated with a value.
But vivado can not find a license.
Hello @sevenclock,
Can you please share a copy of your XINFO report (generated on the machine where you are seeing this licensing error), for examination?
​Xinfo.txt can be generated by running the "report_environment –file xinfo.txt" command in Vivado TCL console.
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
plugged flexid usb device directly on my machine running vivado 2017.1  report_environment –file xinfo.txt -> host id matches
plugged flexid usb device directly on my machine running vivado 2017.3  report_environment –file xinfo.txt -> host id does not match
regards
Hello @sevenclock,
As explained already, for Vivado 2017.3, you'd need to follow the steps in the below AR to get your dongle detected correctly. Please follow these steps and you'd then be able to overcome this issue.
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
I already did this the first time you told me but with no success
Hello @sevenclock,
Can you please share a screenshot similar to my screenshot in the previous post, where it can be seen the files were copied correctly into these 2 locations?
Also, is dongle's Red light ON when you plug in it to the PC?
Even if Xinfo shows NO, running lmutil lmhostid -flexid from C:\Xilinx\Vivado\2017.3\bin\unwrapped\win64.o, do you get your Flex ID populated here? Or do you still see "" instead (so no value populated)?
If no value populated, that means your dongle can't be detected.
-Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
red light is ON!
running  lmutil lmhostid -flexid from C:\Xilinx\Vivado\2017.3\bin\unwrapped\win64.o => value populated "FLEXID=9-01638ea5"
Hello @sevenclock,
If running  lmutil lmhostid -flexid from C:\Xilinx\Vivado\2017.3\bin\unwrapped\win64.o => value populated "FLEXID=9-01638ea5", then the solution provided was applied correctly. Thanks for confirming this.
Even if you see Host ID NO in VLM and Xinfo, this is a visual issue, so please ignore this. However as lmutil lmhostid -flexid returns a valid Dongle's ID, that means Vivado 2017.3 should detect this too and the license should work fine in 2017.3.
Can you please close and then re-open Vivado 2017.3 and then try to Synthesis your design and see if you are still seeing the same licensing error this time or not?
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
already tried several times! License still not found!
Thank you for your effort
Then this means that Vivado can't find the location where the license is located in.
In VLM, go to Manage Licenses Search Paths, and set XILINXD_LICENSE_FILE to point to a folder where you've copied your license file.
Then, close your current Vivado 2017.3 tool (please note that Vivado session needs to be closed and re-open in order for the new license to get detected by the tool) and then see if you still seeing the same licensing error or not.
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
still no success!
Hi @sevenclock,
Then please share with me a copy of your licence file and Xinfo report generated on the machine where you see this licensing issue.
I would need a full Xinfo report for examination, so if you can't share this directly in this Forum thread, then please forward these to me directly via the private message. I would need to examine these files,to be able to see what is causing this issue.
Anatoli
Kind Regards,
Anatoli Curran,
Hi @anatoli
how to send .txt/.lic files via private message?
Hope this helps.
Anatoli
Kind Regards,
Anatoli Curran,
