Virtex 5 QV radiation hardent device not availble in xilinx 14.7
for  space payload back-end processing design which is developed on FPGA platform ,we need higher version  radiation harden Virtex 5 QV series device . In Xilinx 14.7,virtex 5 QV radiation harden series  is not available. How can we resolve this problem?
Re: Virtex 5 QV radiation hardent device not availble in xilinx 14.7
Virtex 5 QV radiation hardent device only supported in  ISE 13.2. These devices not supported in ISE 14.7
https://www.xilinx.com/support/documentation/data_sheets/ds692_V5QV_Data_Sheet.pdf
https://www.xilinx.com/support/documentation/user_guides/ug156-tmrtool.pdf
Thanks and Regards
Balkrishan
