Virtex II Pro and ISE
I need to do some update for an old product using Virtex II Pro. The current version we use is 8,1 and it seems it needs to be run on Windows XP.
What is the latest ISE and EDK version supporting Virtex II Pro?
Can I run that on Windows 7? Windows 10?
Cheers
Re: Virtex II Pro and ISE
@phifred
ISE 10.1 is latest tool which supports Virtex II.
You can try with Linux version RHEL 4.0, RHEL 5.0, SUSE 10 32, 64 bits as mentioned in the below link:
https://www.xilinx.com/support/answers/18419.html
Rohit
Rohit
Hi @phifred
Please have a look at the below link:
https://www.xilinx.com/support/answers/15938.html
No, these OS are not officially supported.
Rohit
Rohit
Thanks for a very fast reply!
I have very hard to get a XP machine.
I have not used the ISE Linux version.
Do you recommend trying to get a XP or should I set up a Linux? Can I move the project files (EDK,ISE) and run them on Linux?
@phifred
Rohit
Rohit
Hi thakurr!
I'll try the Linux version. Thanks!
