Vitis/Vivado download/install username/password trouble (solved?)
When I try to install Vitis or Vivado on Windows I have to enter my username and password 3 times and the last time always fails.  This started happening after I changed my password at Xilinx's behest.  Additionally, Vitis/Vivado installs successfully on Linux without giving me all this username/password grief.  Vivado doesn't work but that is a separate issue.
I got Vivado to install by downloading the big gzipped tar file.  But I wanted to add Vitis so I uninstalled Vivado and now the web installer works!  Argh!
Re: Vitis/Vivado download/install username/password trouble (solved?)
Thanks ... not anymore.  I just kept trying different things until it worked.  Voodoo.
Hi @dougjam
Are you still experiencing issues with the download?
