dylanlewis
Vivado 2015.2 Installer could not connect to internet
I'm getting this issue from the trying to install Vivado 2015.2 from the installer. I've attached an image. The 2017.2 installer works. However, I want to install the 2015.2 version.
u4223374
Advisor
Advisor
@dylanlewis Since Vivado 2015.2 is now unsupported, it's possible that Xilinx no longer maintains the online install archives. You could download the full installer (although it's huge) which does not require internet access.
thakurr
@dylanlewis
Can you make sure your internet connectivity is proper while installing?
Rohit
Rohit
dylanlewis
My internet is definitely working. The 2017.2 installer has no trouble, only the 2015.2 installer.
u4223374
Advisor
Advisor
