Vivado 2015.2 Simulation Failed
Greeting,
I get the following message trying to simulate
Vivado Simulator 2015.2
ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Please see the Tcl Console or the Messages for details.
ERROR: [USF-XSim-62] 'simulate' step failed with errors. Please check the Tcl console or log files for more information.
launch_simulation: Time (s): cpu = 00:00:05 ; elapsed = 00:00:06 . Memory (MB): peak = 1610.035 ; gain = 327.555
attaced my .lic and .xml.
Sean
Re: Vivado 2015.2 Simulation Failed
The licenses which you have are SDK and ISE webpack license with these licenses you can't use Vivado simulator.
You can use Vivado webpack or 30-days evaluation license to run Vivado simulation
Thanks for the quick reply!
Our FPGA design class last for 4 months, is there a way to extend the 30 trial for such period?
Sean
NO, you can't extend Vivado evaluation license for 4 months.
It is valid for 30 days only.
You can use Vivado webpack license which supports limited devices.
I got a similar error.
INFO: [USF-XSim-8] Loading simulator feature
Vivado Simulator 2015.3
launch_simulation: Time (s): cpu = 00:00:02 ; elapsed = 00:00:17 . Memory (MB): peak = 1120.074 ; gain = 0.000
And in VLM, it shows that I have a valid simulation license. Do I need some other license or is it some other error?
Thank you,
Francy
Hello @francyjohn,
It is recommended to create new thread for fresh query.
You can check this thread
https://forums.xilinx.com/t5/Installation-and-Licensing/Common-17-345/m-p/660596#M13272
Ashish
Moving to Licensing Board.
Debraj
Hi @francyjohn
The issue is version limit.
Here is the answer record that explains version limit: http://www.xilinx.com/support/answers/33770.html
Vinay
