paulmariano
Vivado 2015.3 webpack, untrusted license
Howdy,
I've recently become unable to synthesize due to licensing issues. After searching this forum I have found many similar problems but it seems that I need a repair_response.xml file to fix it. Please let me know if you need any additional information. Thank you for your time.
Running
xlicclientmgr -v
I get
U if untrusted
. D if disabled
. . fulfillmentType
. . . Expiry   Count FulfillmentId                   ProductId
U . 6 permanent    0 211861102                       209856468
U . 6 permanent    0 211861174                       209855590
vuppala
Hi @paulmariano
How did you generate this repair_request.xml files?
I observed there are multiple fulfillmentIDs in the repair_request.xml which are not matching with the output of xlicclientmgr -v
Vinay
paulmariano
Hi vuppala, thanks for the reply. I used xlicclientmgr -cr repair_request.xml –repairAll to generate those requests. When I looked at the request files I saw the ones I listed and two old expired 30 day trials. I apologize, I didn't know they were relevent but they should match these:
U if untrusted
. D if disabled
. . fulfillmentType
U . 6 28-sep-2015  0 211861175                       209856469
U . 6 28-sep-2015  0 211861176                       209855615
vuppala
Hi @paulmariano
I sent you the response file through email.
Save the response file and process it using the command: xlicclientmgr -p repair_response.xml
Vinay
paulmariano
Hi vuppala,
The file worked and everything was fine for that session but in the next session the licenses were untrusted again and the response can't be reused. Do you know what could cause this?
vuppala
Hi @paulmariano
Reasons for licenses getting untrusted: http://www.xilinx.com/support/answers/63683.html
Vinay
