Observer deanbruce
Vivado 2015.4.2 update : licence is now not valid?
I have been using Vivado 2015.4
This morning I updated to 2015.4.2
Now i get the following message :-
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z045'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
I have a node locked licence that came with a zc706 dev kit  that is now more than one year old.
should it not work with this minor revision update?
If not how do i restore to version 2015.4 as it doesn't seem to be available via the website
Thanks for any help that you can give on this..
Dean
Re: Vivado 2015.4.2 update : licence is now not valid?
@deanbruce,
If your issue is resolved, please close this thread by marking appropriate reply as solution.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Hi @deanbruce,
Please post your license file here.
For using Vivado 2015.4.2, you need version limit as 2016.02, while you need 2015.11 as version limit for using Vivado 2015.4.
Refer this AR for details: http://www.xilinx.com/support/answers/33770.html
Install Vivado HLx from this link:
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-4.html
Nupur
Observer deanbruce
is the licence limited to one year and a month or is it the version number then?
assuming it has expired, how can i re-download design suite 2015.4
thanks
@deanbruce,
It is decided by the version limit mentioned in the license(in your case 2016.01, which does not allow you to use 2015.4.2) .
Use this link ( http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-4.html ) to install 2015.4 .
Nupur
Observer deanbruce
I incorrectly assumed that the HLX download was for vivado HLS also i thought that the web install client was for the web edition
doh !
@deanbruce,
Nupur
you can't reward back old version of tool. you need to unstall and install again .
I would recommend you to renew Vivado license and use latest which is Vivado 2016.2
Thanks and Regards
Balkrishan
