drjohnsmith
Vivado 2015.4 , Max threads
on the last few versoins of vivado,
the get_parameter general.maxThreads has returned on this machine 4
  in 2015.4, I'm now getting 2.
Im in GUI mode, none script, press the gui botttons and away we go.
How do  I get vivado to set maxThreads back to 4 please.
the only way I see so far is each and every time I open vivado I have to go to the tcl terminal and enter
set_parameter general.maxThreads 4
which is a pain in the kicker,
ta
randyh
When I used set_parameter I got an invalid command name error. Using set_param in the way you described works fine for me in 2015.4:
set_param general.maxThreads 4
I am also running Windows 7 64-bit.
Best regards,
Randy
vuppala
Hello @drjohnsmith
Follow below steps:
1. Create a tcl file with name init.tcl and with only below tcl command:
2. Place this init.tcl file in the following location: <installdir>/Vivado/version/scripts/
Check this answer record for more information: http://www.xilinx.com/support/answers/53090.html
Vinay
drjohnsmith
So put a filt init.tcl in my 2015.4/scripts folder
contents of file
vivado does not start,
Error when launching vivado.bat: launcher time out
windws 7 pro 64 bit
randyh
Best regards,
Randy
drjohnsmith
thank you
that was it.
