Vivado 2015.4 installation issues
Have been using 2015.4 version and recently downloaded the update to 2015.4.1
Running the setup fails with a message that it cannot find a valid installation to update.... but I have been using it just fine.
Anyone know why this might happen and how to work around it?
This might be complicated by the installation being at G:/Xilinx instead of C:...
Re: Vivado 2015.4 installation issues
Hello @dave_lautzenheiser
Check this answer record: http://www.xilinx.com/support/answers/63720.html
Vinay
