optimumsemi
Vivado 2017.3 Update 1 (2017.3.1)
I installed Vivado 2017.3 successfully and need to update to 2017.3.1. Once I downloaded this update package into an existing 2017.3 installation directory and following script ./xsetup, and seeing the following message (log file is attached):
gpu-admin@OST-GPU:/opt/Xilinx/Vivado/2017.3/Xilinx_Vivado_SDK_2017.3.1_1023_1$ ./xsetup
INFO : Log file location - /home/gpu-admin/.Xilinx/xinstall/xinstall_1545264444658.log
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    at java.io.File.<init>(File.java:277)
    at com.xilinx.installer.gui.panel.summary.SummaryPanel.b(Unknown Source)
    at com.xilinx.installer.gui.panel.summary.SummaryPanel.B(Unknown Source)
    at com.xilinx.installer.gui.D.a(Unknown Source)
    at com.xilinx.installer.gui.InstallerGUI.l(Unknown Source)
    at com.xilinx.installer.gui.i.actionPerformed(Unknown Source)
    at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
    at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
    at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
    at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
    at java.awt.Component.processMouseEvent(Component.java:6533)
    at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
    at java.awt.Component.processEvent(Component.java:6298)
    at java.awt.Container.processEvent(Container.java:2236)
    at java.awt.Component.dispatchEventImpl(Component.java:4889)
    at java.awt.Container.dispatchEventImpl(Container.java:2294)
    at java.awt.Component.dispatchEvent(Component.java:4711)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
    at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
    at java.awt.Container.dispatchEventImpl(Container.java:2280)
    at java.awt.Window.dispatchEventImpl(Window.java:2746)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
    at java.awt.EventQueue.access$500(EventQueue.java:97)
    at java.awt.EventQueue$3.run(EventQueue.java:709)
    at java.awt.EventQueue$3.run(EventQueue.java:703)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
    at java.awt.EventQueue$4.run(EventQueue.java:731)
    at java.awt.EventQueue$4.run(EventQueue.java:729)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
 Can someone please help? Thanks!
anatoli
Hello @optimumsemi,
What exact Operating System are you seeing this issue on? Can you confirm on this please? Thanks in advance.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
optimumsemi
Our Operating System is Ubuntu 18.04.
Thanks for your help,
Optimumsemi
