Vivado 2017.3 installation
I installed Vivado 2017.3 design on driver C before and it work properly. Recently because I do not have enough space on C driver, I uninstalled Vivado and reinstall it on driver D. After installation, it indicated that there was an exception during generating device list. And when I tried to open Vivado, after about 2 minutes, there is dialog said:
Error when launching 'D:\Xilinx\Vivado\2017.3\bin\vivado.bat': Launcher time out.
I uninstalled Vivado 2017.3 and tried to reinstall again, still have the same problem. What should I do to solve it?
Re: Vivado 2017.3 installation
The problem has been solved. It is because of the windows 10 update. Windows did an update recently, that's why I do not have enough space on C driver and have to reinstall vivado on D driver. The solution is as below:
https://www.xilinx.com/support/answers/69908.html
Hi @savvysky,
Can you please have a look into this AR and follow its suggestions to overcome this issue?
https://www.xilinx.com/support/answers/57386.html
hemangd
hemangd
Hi @savvysky,
Try invoking vivado.bat through cmd.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
 Hello @savvysky,
Can you please try setting the System Environment Variable XIL_PA_NO_REDIST_CHECK to 1 and logging out and logging in and then see if you can overcome this issue that way?
The problem seems to be xvcredist.exe. It is called by loader.bat.
It seems a check for the Visual C++ runtime (xvcredist -check) is not working correctly so loader is attempting to install it. So setting XIL_PA_NO_REDIST_CHECK to 1 should work for you. If not, please let us know.
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
I opened vivado.bat with cmd, the following window appeared for two seconds then quit.
There is no System Environment Variable XIL_PA_NO_REDIST_CHECK. So I created a new  System Environment Variable XIL_PA_NO_REDIST_CHECK, set its value to 1. But the problem is still there.
