10-08-2018 06:36 AM
I'm installing Vivado 2018.2 on a VM running Ubuntu 16.04.3 LTS (64-bit), as UG973 prescribes.
During installation, I can read the following in the installer dialog: 'additional library installation required' :
now in UG973 (2018.2) page 39, there's a paragraph refering to AR# 66184 : Install - How do I find out which libraries are required to run Vivado tools in Linux?
Q1) now this AR# looks rather old to me, and talks about 2015.4 ... is the perl script still valid for 2018.2?
Q2) I'm not a perl hero, could someone explain what this script actually does? Is it checking what libraries are used by Vivado/SDK/... executables, and then checking if these libraries are present in their correct versions on the host OS? What if there are missing libraries, are these reported? Or does the perl script just throw out a list of libraries, and do I need to check these one by one to see if they are installed?
10-09-2018 08:09 AM
Hi @ronnywebers,
Correct this script is still valid with the Ubuntu install flow as some additional 32-bit libraries may be required. That script first checks which libraries are missing and then installs as needed through the executable in the install.
Thank you,
Devin
10-09-2018 08:09 AM
Hi @ronnywebers,
Thank you,
Devin
10-11-2018 07:46 AM - edited 10-11-2018 08:08 AM
thanks @devinl, I just ran the perl script, and I get missing libraries, but I created a new thread here because it goes away from the original question - thanks for the help so far!
If you wouldn't mind having a look at the follow-up post :
Vivado 2018.2 install on Ubuntu 16.04.3 LTS :libstdc++.so.6: version `GLIBCXX_3.4.22' not found
