ruckman_slac
Vivado 2019.2 Support for Ubuntu 19.04 ???
https://forums.xilinx.com/t5/Vivado-TCL-Community/Vivado-2019-1-installation-on-Ubuntu-19-04/td-p/1000457
Ubuntu 19.04 is not supported in Vivado 2019.1 release
Will the Vivado 2019.2 release support Ubuntu 19.04?
anatoli
Hello @ruckman_slac ,
I can confirm that the support for Ubuntu 19.04 is not on the readmap of supported OSs for 2019.2.
Therefore, it is recommended to use one of the supported versions of Ubuntu: 16.04 or 18.04 for Vivado 2019.x
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
rshekhaw
Hi @ruckman_slac ,
There is a possibility of its support. But the surety on that can only be shared at the day of release.
Raj
anatoli
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
vanmierlo
Mentor
Mentor
Since Ubuntu 19.04 is not an LTS version I believe it is unlikely that any professional tool will officialy support it.
