Vivado 2020.1 upgrade from webpack to HL System Edition hang
I install Vivado System Edition License first, and try to upgrade from Webpack version to Vivado HL system edition or Vivado HL Design Edition but it hangs on "Select Extra Content" panel. It cannot pop up any content on this window and "Next' Button not works. How do I fix this error?
Hi @tommycc,
This issue will be observed if the destination doesn't have sufficient memory for the Upgrade. Since you are planning to upgrade from WebPack to HL System Edition, it should need some 50GB approx. Based on this, can you clear the space and try the upgrade again.
Aravind.
Hi @tommycc,
Aravind.
However,my disk have 292GB available free space. I think it has other issue.
Thanks for your replay.
Sorry
I forgot to change install directory permission so it hang on there.
I solve this issue now.
