Vivado 2020.2 to 2020.2.2 update issue
Hello I have done the update for Vivado 2020.2 and now I am having this problem:
Do you know why that happened?
Alexandros
ansarimo
Hi @alexandros-kapouranis
Please refer to the below similar post and check if it helps:
https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2015-2-Installer-fail/m-p/1163825/highlight/true#M30677
For Vivado 2020.2, Vcredist required is either 2015 or 2017, refer to the above post for more details.
Also, I see that you are sourcing init.tcl file while invoking Vivado, kindly rename it to Vivado_init.tcl as tool may get confused over this.
Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
anatoli
Hello @alexandros-kapouranis ,
This topic is still open and is waiting for you.
If your issue is not solved yet, please reply in the thread, so that we can further assist you with your issue.
However, if your question is answered and/or your issue is solved, please mark a response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.  We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
