kmorris
Vivado 2021.1 Licensing Changes
Update in relation to Vivado 2021.x licensing change:
We are very excited to announce the release of Vivado ML 2021.1 – packed with many features.
You can download Vivado/Vitis ML 2021.1 release from Xilinx’s Download page and refer to the following user guide for more details on what’s new in Vivado 2021.1 release - UG973: What’s new, Licensing and Installation
In this release of Vivado we are introducing changes for licensing that we would like to bring to your attention.
Vivado ML 2021.1 Licensing Changes:
1. Starting with the Vivado 2021.1 release, Flex licensing management tools have been upgraded to Flexlm 11.17.2.0. version. Some key points to note are:
  • If you are using floating licenses, then you must upgrade licensing utilities to Flex 11.17.2.0. New licensing utilities can be found on the download pagewww.xilinx.com/downloads
  • Flex version upgrade does not affect valid license files, in other words, existing valid license files will work with the Vivado 2021.1 release after you upgrade the licensing utilities.
  • Vivado 2020.3 will be the last release that will support licensing utilities for Flex 11.14.1.
  • We will continue to support licensing utilities for Windows and Linux operating systems (64-bit versions only)*
*For the full list of Operating System (OS) support for Licensing 11.17.2.0 Utilities, please check the Readme.txt file that comes with the downloaded utilities.
 Note: With the new utility upgrade, if an `GLIBC_2.14' not found error is seen, please check Xilinx Answer Record AR#76653 on how to overcome this issue.
2 . USB Dongle Drivers
  • Using USB dongles for licensing will require you to install drivers on windows
Please refer to AR#47132 for more details on how to install USB dongle drivers on windows.
Please don’t forget to reply, kudo, and accept as solution!
akugel
Xilinx daemon doesn't start after upgrading FlexLM:
12:40:56 (lmgrd) (@lmgrd-SLOG@) ===============================================
12:40:56 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
12:40:56 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Oct 12 2017 12:40:56 Mitteleurop?ische Sommerzeit
12:40:56 (lmgrd) (@lmgrd-SLOG@) PID: 2924
12:40:56 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.0 build 194335 i86_n3 ( build 194335 (ipv6))
12:40:56 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
12:40:56 (lmgrd) (@lmgrd-SLOG@) Listening port: 2100
12:40:56 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
12:40:56 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
12:40:56 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
12:40:56 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Licenses\Xilinx_ziti_2017.lic -l C:\Licenses\Xilinx.log -z -s
12:40:56 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  C:\Licenses\Xilinx_ziti_2017.lic
12:40:56 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
12:40:56 (lmgrd) Starting vendor daemons ...
12:40:56 (lmgrd) Starting vendor daemon at port 1188
12:40:56 (lmgrd) Using vendor daemon port 1188 specified in license file
12:40:56 (lmgrd) Started xilinxd (pid 2164)
12:41:01 (lmgrd) xilinxd exited with status 53 (this status is reserved but will never be generated)
12:41:01 (lmgrd) Since this is an unknown status, license server
12:41:01 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
12:41:01 (lmgrd) Starting vendor daemon at port 1188
12:41:01 (lmgrd) Using vendor daemon port 1188 specified in license file
12:41:01 (lmgrd) REStarted xilinxd (pid 944)
12:41:06 (lmgrd) xilinxd exited with status 53 (this status is reserved but will never be generated)
12:41:06 (lmgrd) Since this is an unknown status, license server
... many more of this ....
12:44:04 (lmgrd) Starting vendor daemon at port 1188
12:44:04 (lmgrd) Using vendor daemon port 1188 specified in license file
12:44:04 (lmgrd) REStarted xilinxd (pid 1388)
12:44:09 (lmgrd) xilinxd exited with status 53 (this status is reserved but will never be generated)
12:44:09 (lmgrd) Please correct problem and restart daemons
Any clues?
The "never generated status" apparently is generated though ...
anatoli
Hello @akugel,
Please note that this error (“xilinxd exited with status 53”) is typically seen on Windows license servers where the license utilities were downloaded separately and Vivado is not installed.
This error can occur if the Microsoft Visual C++ redistributable libraries are not installed on the Windows machine.
Please note that the 11.14.1.0 license utilities require that the machine have the 2015 Microsoft Redistributables installed before running.
This is normally provided as part of the Vivado install, however if/as you are setting up a floating server outside of Vivado, you can obtain the redistributables from Microsoft:
https://www.microsoft.com/en-us/download/details.aspx?id=48145
Therefore, can you please obtain the redistributables from Microsoft link above and installed this on the server and then stop and start the server again and then see the output, as this should fix this issue.
Please try the above and let me know the output.
Hope this helps.
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
akugel
Thanks, works OK after installing the VS runtime.
I have installed 2017.3. I have also installed the drivers and copied the DLLs as outlined in AR# 47132. The Vivado License manager does not see the FLEXID dongle ID. However, my previous installation of ISE 14.6 does still see it. The operating systems is Windows 7, and I have re-booted the system (several times!). The device manager confirms that the driver version for the dongle on USB is 7.50.0.0, which is, I think, what comes from AR# 47132. So how should I proceed?
virtex
I  just posted that we had problems with the LMtools creating the service with the wrong account.  it used the "network system" account instead of the "system" account ,   service wouldn't start using the "Network System" account.  We had to manully change the account ins the service to get it to run.    just and FYI.     I guess the permissions are different between the two account on the server.
kailashprakash
Since the support for activation based license has been discontinued. WIll the borrowing features in certificate based license be enabled?.
anatoli
Hello @kailashprakash,
Currently licensing borrowing isn't support with CB licensing.
Based on why I'm aware of, there was something in the roadmap for certificate license borrowing, but I haven't heard anything about it. So if that's going to happen, won't be soon.
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
michaeltymcnamara
Is License Queuing available with version 2017?
ycakilci
anatoli
Hello @ycakilci,
I can see you have posted an empty post here, without providing any info of the query. Please share your issue or the questions you have and we'll be glad to help you then.
Have a nice day
Kind Regards,
Anatoli Curran,
Versal Blogs
mitchjw
Hi-
We have a kind of unique situation in our Enterprise. We have a floating Xilinx license and some stand-alone licenses. For the compiling we do, we need some of the features from the floating license and some from the stand-alone license. We also need to do everything off-network in some situations when we're in the field in remote destinations with no Internet access.
Based on the above description, we would need to license borrow from the floating license and acces features on the stand-alone license. Due to the specifics, we would really like to set up a meeting with an application specialist to discuss.
Is that something you can help us with?
TIA,
James
jameswmitchell@drs.com
anatoli
Hello @mitchjw ,
Please note that license borrowing isn't supported with the Certificate Based licensing methodology.
Please note that if you have your floating license as well as your Node-Locked license on the same machine where you've installed your Vivado tools, then in this case, you don't need access to the Internet at all, as Vivado will be able to detect both licenses locally on this specific PC.
However, if you have your Node-Locked license on the PC where you have Vivado installed, however your Floating license is run somewhere else on the network, i.e. on a main floating license server that is only accessible when you are on a local network, then if the network isn't accessible, in this case your floating license won't be reachable, and hence Vivado will only be able to work with your Node-Locked licenses.
In any case, if you are working with the latest Vivado releases, license borrowing isn't supported, as this is the FlexLM (Flexera) limitations, that is not supported with Xilinx licenses.
There is in fact a Flexera related licensing admin guide (see attached) v11.14.0 "License Administration Guide", chapter "License Borrowing with BORROW", however instructions are not compatible with Xilinx licenses, as it requires to make some s/w changes to make it practical with Xilinx floating licenses.
Hope the above is clear.
Kind Regards,
Anatoli Curran,
Versal Blogs
