Vivado Activation Based Licenses Greyed Out - WebPACK
I've read all the post and tried all the solutions I can find to the problem of the Vivado license page being greyed out.
I'm trying to get a WebPACK license for a machine that previously had Vivado installed and in which I had a OS failure that required a full reinstall. Clearly, this meant I was unable to return the license I previously had.
I've tried every command I can find and even created a new account. Nothing has worked so far.
It's pretty poor how Xilinx thinks that engineers spending literally days on license problems is an acceptable state of affairs.
Re: Vivado Activation Based Licenses Greyed Out - WebPACK
Hi @hgomersall1
Please file a service request here to return your license back to your account.
Vinay
