Vivado Design Suite - HLx Editions - 2019.2 signature cannot be downloaded
I cannot download the signature file for Vivado Design Suite - HLx Editions - 2019.2 (https://www.xilinx.com/support/download/2019-2/vivado/Xilinx_Unified_2019.2_1106_2127_Lin64.bin.sig). Is it just me?
Renaud Pacalet
Re: Vivado Design Suite - HLx Editions - 2019.2 signature cannot be downloaded
Hello @pacalet ,
This is a Firefox bug that causes the browser to malfunction while handling the file encoding for these specific file types. This was introduced with Firefox v33.0, and is prevalent on all versions of this browser beyond that. The download works if you happen to have an older version of FF.
In this case, as you've already tried, users would need an alternate browser for downloading the “.digests” files.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @pacalet,
I am able to download the signature file without any issues. Can you check your downloads or browser settings maybe. Or do you see any prompts. Any additional info would help.
Aravind.
Interesting. I tried again (with Firefox 74.0) and when clicking on the button all I get is still:
Alert:
/home/bob/Downloads/ZlnQN9d3.part could not be saved, because the source file could not be read.
Try again later, or contact the server administrator.
Just like yesterday. I tried from different computers, different OSes (Debian Buster and Mac OS Mojave), they all behave the same. Then I tried with Safari and it worked. I tried also by copy-pasting the URL and using wget and it worked too. Apparently it is just Firefox. I disabled all extensions and plugins, still the same. The other buttons work, but not this one. Strange...
Renaud Pacalet
Hello @pacalet ,
Hope this helps.
Kind Regards,
Anatoli Curran,
Oh, I see. Thanks.
Renaud Pacalet
