Vivado HLx 2017.4 batch mode install
I’m running a batch mode install for Vivado and I’m getting the error “The value specified on the configuration file for InstallOption (Install WinPCap for Ethernet Hardware Co-simulation) is missing or invalid” AND “The value specified on the configuration file for InstallOption (Launch configuration manager to associate System Generator for DSP with MATLIB) is missing or invalid.
I've also selected Vivado HL Sytem Edition instead of HL WebPack and still receive same results.
I checked the config file and it looks good – all that was changed is the zero was changed to a 1 to tell it to install. I have also recreated the file and used both Wordpad and Notepad to edit the file thinking maybe it was changing the format but none of this has helped get passed the errors.
Neither of these options have been installed so looking for a fix or workaround to get them installed…
I have attached the config file and a print screen of the error.
Re: Vivado HLx 2017.4 batch mode install
I've also followed the Batch Mode Install Flow found on page 34 here
回复: Vivado HLx 2017.4 batch mode install
These warnings are visual only. The installation is expected to be successful anyway.
The warnings are not displayed starting from 2018.1 installer.
