Vivado Lab 2017.2 won't launch on Windows 10 (1709)
Returns a runtime error with code R6025.
This issue is documented in AR# 69908 (the AR is for 2017.3, but has been reported to work for 2017.2 as well).
However, the proposed workaround is not possible for the Lab Edition of the tools, since there is no 'vivado-vg.exe' located in '(Vivado Installed Directory)\2017.2\bin\unwrapped\win64.o'.
Is there another way around this issue for the Lab Edition specifically?
anatoli
Hello bclarke@harris.com,
What you need here is a vivado_lab-vg.exe executable and then by replacing your current vivado_lab.exe as described in AR# 69908, this should work fine for you then.
You have tested this and everything seems to be working fine for you now. Glad your issue is sorted now.
Have a nice day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
nupurs
bclarke@harris.com
You can try using the latest lab edition, i.e. version 2018.2, which is supported with Windows 10 1709. Lab edition is free and doesn't need a license.
Nupur
anatoli
I've sent you a Private Message with a Workaround to try.
Please give this a try and see if this works?
Kind Regards,
Anatoli Curran,
Versal Blogs
anatoli
Have a nice day.
Kind Regards,
Anatoli Curran,
Versal Blogs
