Vivado License Manager does not recognize CentOS 7 wireless MAC hostid
Vivado License Manager is not recognizing my wireless MAC address.  Yet:
System Info: CentOS 7 64 bit
[Mike@Node4 ~]$ uname -a
Linux Node4 3.10.0-229.14.1.el7.x86_64 #1 SMP Tue Sep 15 15:05:51 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
[Mike@Node4 ~]$ ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 0  (Local Loopback)
        RX packets 155  bytes 12628 (12.3 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 155  bytes 12628 (12.3 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:e9:a5:c7  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
wlp0s29f7u3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.109  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::821f:2ff:fe86:e8df  prefixlen 64  scopeid 0x20<link>
        ether 80:1f:02:86:e8:df  txqueuelen 1000  (Ethernet)
        RX packets 2310  bytes 1585144 (1.5 MiB)
        TX packets 1359  bytes 238094 (232.5 KiB)
[Mike@Node4 ~]$ lsusb
Bus 001 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0bda:0111 Realtek Semiconductor Corp. RTS5111 Card Reader Controller
Bus 005 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 005 Device 003: ID 04f3:01a4 Elan Microelectronics Corp. Wireless Keyboard
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
[Mike@Node4 ~]$
[Mike@Node4 ~]$ yum info NetworkManager-wifi
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
 * base: mirror.lax.hugeserver.com
 * extras: mirrors.syringanetworks.net
 * updates: reflector.westga.edu
Installed Packages
Arch        : x86_64
Epoch       : 1
Version     : 1.0.0
Release     : 16.git20150121.b4ea599c.el7_1
Repo        : installed
From repo   : updates
Summary     : Wifi plugin for NetworkManager
URL         : http://www.gnome.org/projects/NetworkManager/
License     : GPLv2+
Description : This package contains NetworkManager support for Wifi and OLPC devices.
[Mike@Node4 ~]$
[Mike@Node4 ~]$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: wlp0s29f7u3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
    link/ether 80:1f:02:86:e8:df brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.109/24 brd 192.168.1.255 scope global dynamic wlp0s29f7u3
       valid_lft 82802sec preferred_lft 82802sec
    inet6 fe80::821f:2ff:fe86:e8df/64 scope link
3: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN
    link/ether 52:54:00:e9:a5:c7 brd ff:ff:ff:ff:ff:ff
    inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
4: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast master virbr0 state DOWN qlen 500
[Mike@Node4 ~]$
[Mike@Node4 ~]$ iw phy #0
Wiphy phy0
    max # scan SSIDs: 4
    max scan IEs length: 2257 bytes
    RTS threshold: 2347
    Coverage class: 0 (up to 0m)
    Device supports RSN-IBSS.
    Supported Ciphers:
        * WEP40 (00-0f-ac:1)
        * WEP104 (00-0f-ac:5)
        * TKIP (00-0f-ac:2)
        * CCMP (00-0f-ac:4)
        * CMAC (00-0f-ac:6)
    Available Antennas: TX 0 RX 0
    Supported interface modes:
         * IBSS
         * managed
         * AP
         * AP/VLAN
         * monitor
         * P2P-client
         * P2P-GO
    Band 1:
        Capabilities: 0x1862
            HT20/HT40
            Static SM Power Save
            RX HT20 SGI
            RX HT40 SGI
            No RX STBC
            Max AMSDU length: 7935 bytes
            DSSS/CCK HT40
        Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
        Minimum RX AMPDU time spacing: 16 usec (0x07)
        HT TX/RX MCS rate indexes supported: 0-7, 32
        Bitrates (non-HT):
            * 1.0 Mbps
            * 2.0 Mbps
            * 5.5 Mbps
            * 11.0 Mbps
            * 6.0 Mbps
            * 9.0 Mbps
            * 12.0 Mbps
            * 18.0 Mbps
            * 24.0 Mbps
            * 36.0 Mbps
            * 48.0 Mbps
            * 54.0 Mbps
        Frequencies:
            * 2412 MHz [1] (20.0 dBm)
            * 2417 MHz [2] (20.0 dBm)
            * 2422 MHz [3] (20.0 dBm)
            * 2427 MHz [4] (20.0 dBm)
            * 2432 MHz [5] (20.0 dBm)
            * 2437 MHz [6] (20.0 dBm)
            * 2442 MHz [7] (20.0 dBm)
            * 2447 MHz [8] (20.0 dBm)
            * 2452 MHz [9] (20.0 dBm)
            * 2457 MHz [10] (20.0 dBm)
            * 2462 MHz [11] (20.0 dBm)
            * 2467 MHz [12] (disabled)
            * 2472 MHz [13] (disabled)
            * 2484 MHz [14] (disabled)
    Supported commands:
         * new_interface
         * set_interface
         * new_key
         * start_ap
         * new_station
         * set_bss
         * authenticate
         * associate
         * deauthenticate
         * disassociate
         * join_ibss
         * set_tx_bitrate_mask
         * frame
         * frame_wait_cancel
         * set_wiphy_netns
         * set_channel
         * set_wds_peer
         * probe_client
         * set_noack_map
         * register_beacons
         * start_p2p_device
         * Unknown command (92)
         * Unknown command (104)
         * connect
         * disconnect
    Supported TX frame types:
         * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    Supported RX frame types:
         * IBSS: 0x40 0xb0 0xc0 0xd0
         * managed: 0x40 0xd0
         * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
         * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
         * mesh point: 0xb0 0xc0 0xd0
         * P2P-client: 0x40 0xd0
         * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
         * P2P-device: 0x40 0xd0
    software interface modes (can always be added):
         * AP/VLAN
         * monitor
    interface combinations are not supported
    HT Capability overrides:
         * MCS: ff ff ff ff ff ff ff ff ff ff
         * maximum A-MSDU length
         * supported channel width
         * short GI for 40 MHz
         * max A-MPDU length exponent
         * min MPDU start spacing
    Device supports TX status socket option.
    Device supports HT-IBSS.
    Device supports low priority scan.
    Device supports scan flush.
    Device supports AP scan.
[Mike@Node4 ~]$
Re: Vivado License Manager does not recognize CentOS 7 wireless MAC hostid
The workaround for this problem is to disable consistent network device naming by adding 'net.ifnames=0' to the kernel command line.
hi @tud_hartmann
Thanks for posting the solution, It will be helpful for other customers also.
Please clsoe the thread by marking your post as Accepted Solution.
Sorry for the delay in my reply, and many thanks for your response.  I'm working on my CentOS 7 system only on weekends.  I did make the change you suggested.
cat /etc/default/grub
GRUB_TIMEOUT=5
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX="crashkernel=auto rd.lvm.lv=centos00/swap rd.lvm.lv=centos00/root rhgb quiet net.ifnames=0 biosdevname=0"
GRUB_DISABLE_RECOVERY="true"
From what I can tell the only thing this change seems to have done is rename my Ethernet nic to wlan0.  Unfortunately, the Vivado License Manager still does not recognize my MAC address.  Here are the outputs of various commands which hopefully is enough to identify the issue.
ifconfig
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
Mike@Node4~]$lsusb
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
inet 192.168.1.109/24 brd 192.168.1.255 scope global dynamic wlan0
valid_lft 83864sec preferred_lft 83864sec
Hi mlegako@gmail.com
Rename your NIC card to ethX to recognized by the Vivado License Manager tool.
Vinay
virbr0 is a virtual network device provided by libvirt and can't get renamed. I guess you are not inside the virtual enviroment. But do you have any other (wired) network adapter beside wlan0?
