Bill1
Vivado Unified Installer 2020.1_0602_1208 not launching at Windows 8
Hello. I downloaded the installation launcher for the version of Vivado mentioned above. The program launches, it extracts the launcher and then it shuts down without doing anything.
I've installed both the x64 and the x86 of the Microsoft C++ 2015 Redistributable and the Server Service is running (as I've seen at other posts on this forum).
Any help would be appreciated.
Tags (2)
agovinda
Hi @Bill1,
Vivado is not supported in Windows 8. And so there wasn't any testing done on Windows 8. Can you give it a try using Windows 10 ?
If Windows 10 is not an option, I would suggest installing the 2017 Microsoft VC++ Redist files and give it a try. But I am not sure if it will still work as Windows 8 is not a supported OS.
Aravind.
agovinda
Hi @Bill1,
Aravind.
