Vivado WebPACK License is locked on a computer I don't have access to
I have installed Vivado WebPACK on a laptop that I unfortunately don't have anymore.
I would like to remove that license and get a new one for my current computer, this doesn't seem to be possible since the "modify license" button is greyed out.
What should I do?
Thank you.
Re: Vivado WebPACK License is locked on a computer I don't have access to
Hi @mlu1109
You need to return the Vivado webpack license from the computer on which you have already installed.
Once you return it successfully, it will be added back to your account.
Then you have to generate it again for your new computer.
This below AR has the details on how to return the license.
http://www.xilinx.com/support/answers/60525.html
Thanks for your fast reply!
I don't have access to that computer anymore, I wiped the hard drive and sold it.
Foolishly I did not know that I couldn't disable the license after doing that.
Is there no other way to retrieve the WebPACK license?
Hi @mlu1109
Only one webpack entitlement will be provided with each account.
We dont have any other option now rather than returining the license and generating it for new machine.
Is there no way you can revoke that license? The software is not on that computer anymore.
Try filing a Service Request with the customer service team here:
http://www.xilinx.com/support/service-portal.html
Nupur
I tried registering for the service portal but I was denied because I'm a student.
How can I get this reviewed without the service portal?
Thank you.
I have the same problem . My computer is dead .
I would like to remove that license and get a new one for another computer, this doesn't seem to be possible since the "modify license" button is greyed out.
What should I do?
have you find a solution ?
Thank you
Hi @mlu1109,
As you do not have access to the service portal.
Please contact one of your faculty person/ professor who has valid account and ask to rise request for the same.
This is the only way to resolve the issue now.
Yash
Unfortunately this isn't really an option.
I guess I'll have to use the ISE Design Suite from now on.
@nramat: Nope, license is lost.
