Visitor parampampam
Vivado and ISE problem on Windows 7 x64
I have installed Vivado 2014.4 and it doesn't start. I get the following error when I try to run it:
Error when launching 'E:\Xilinx\Vivado\2014.4\bin\vivado.bat': Launcher time out
I tried to run vivado.bat via console and got this error:
application-specific initialization failed: couldn't load library "librdi_commontasks.dll": this library or a dependent library could not be found in library path
Then I tried to open librdi_commontasks.dll in Dependency Walker and it showed me lack of the following DLLs:
API-MS-WIN-APPMODEL-RUNTIME-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ERROR-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
API-MS-WIN-SHCORE-SCALING-L1-1-1.DLL
DCOMP.DLL
IESHIMS.DLL
JVM.DLL
I have tried to install previous versions of Vivado and got the same error. ISE works fine, but PlanAhead crashes with the same error. I also have tried to install Microsoft Visual C++ Redistributable Package from tps folder of Vivado. This hasn't helped me.
Please help me to solve this problem. Thanks in advance.
Regards.
Visitor parampampam
Re: Vivado and ISE problem on Windows 7 x64
Hi, everyone
I've finally solved this problem!
I opened properties of vivado.exe and cmd.exe in ProcessExplorer (look at the screenshots) and noticed useful information. As you can see, cmd.exe had right PATH value, but vivado.exe didn't have. I tried to google string "nvInitDll redirect success" and found this http://stackoverflow.com/questions/4504074/nvinitdll-redirect-success-malforming-path Then I just removed registry key AppInit_DLLs from HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Windows using regedit utility. Now Vivado works fine!
Thanks for your answers, guys.
Can you run the below command and share the output?
report_environment -file <directory>/xinfo.txt
Kill Vivado.exe in Windows taks manager->Processes tab and try reopening Vivado.
Thanks,Vijay
Visitor parampampam
report_environment command can't be found in windows shell.
Visitor parampampam
I tried, but it didn't help.
Open the Vivado TCL shell and run the command.
Start Menu ->All programs -> XIlinx Design tools -> Vivado 2014.4 -> Vivado 2014.4 Tcl shell
Visitor parampampam
I can't do this because Vivado TCL Shell has the same error with DLL. Please, look at my screenshot.
  • Can you compare md5sum value of the downloaded Vivado 2014.4 installer zip file with the md5sum value provide in the downloads website?
You can use fastsum tool to get the md5sum value. The steps to get this are given below.
  1. Download the fastsum tool from the link,​ http:/​/​www.fastsum.com/
  1. Provide your downloaded Vivado installer ZIP file (2014.4 installer .tar file) to the tool to get the checksum value.This value should match with the one provided in the Xilinx website, http://www.xilinx.com/support/download.html
Visitor parampampam
I used webinstall for installation Vivado and I don't have installation archive. I'm going to download full archive, install Vivado again, check sum of archive and give you the results.
Visitor parampampam
I've checked the checksum of my archive. It matches to sum from xilinx.com. What can I do else to solve this problem?
Did you try installing Vivado by extracting the downloaded .tar file?
Vinay
Visitor parampampam
Yes, I unpacked .tar with WinRAR and then started installing.
Are you able to install the Vivado 2014.4 and start it now?
If the issue is resolved please close this thread by marking the post which helped you as Accepted Solution.
It will definitely help the other forum users.
Visitor parampampam
Hello, Manusha
I have reinstalled Vivado 2014.4 from the checked .tar archive. But I still have the error.
Regards.
Can you check if the MYVIVADO environment variable is set on your machine?
If it is set can you unset it and check if it helps?
Visitor parampampam
I don't have this variable. You can see all my variables on the screenshot.
I see a special character in username TEMP environment variable.
Can you please try renamning the username without any special characters in it?
Can you change your system language settings to english and check?
Vinay
Visitor parampampam
I have changed it to "C:\Temp". But I still have the same error.
Visitor parampampam
Hello, Vinay
I changed my system language to English, but it didn't solve the problem.
Regards.
Hello @parapampam
Do you have any other version of Xilinx Tools on the machine?
If yes, can you share xinfo.txt. To generate xinfo.txt, see this answer record: http://www.xilinx.com/support/answers/55414.html
If you have ISE, generate xinfo using start --> All Programs --> Xilinx Design Tools --> ISE Design Suite 14.x --> Accesories --> Xinfo System Checker.
Vinay
Visitor parampampam
Hi, Vinay
I've found xinfo.exe inside installation pack of ISE and run it. Please, look at my xinfo.txt file.
Regards.
Visitor parampampam
Hello, everyone.
I tried to copy librdi_commontasks.dll from E:\Xilinx\Vivado\2014.4\lib\win64.o\ to E:\Xilinx\Vivado\2014.4\bin\unwrapped\win64.o and got another error (look at the screenshot). I think Vivado can't find DLLs in E:\Xilinx\Vivado\2014.4\lib\win64.o\ for some reason. Do you have any suggestions how to make Vivado see these DLLs?
Regards.
Visitor parampampam
Hi, everyone
