rabeluk
Vivado default browser
Hi dear,
I would like to change my Vivado default browser but I'm not able to do this. Can someone say me if ther'is a way to do this?
best regards
balkris
it must be your OS default browser. you can also check tools--> settings
Thanks and Regards
Balkrishan
prathikm
Hi @rabeluk,
In Vivado 2017.2 > Settings > Help > Documentation > Open with your web browser.
- If explorer is your default browser, any documentation should open in that. If you need to change it, for example to chrome, make chrome as default browser in system and the documentation from tool should open in chrome.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
rabeluk
I'm using on Fedora. When I set chrome like default browser it doesn't work well. I needed to uninstall all others browsers. Vivado now is using konquerer. I tred to remove its, but vivado wasn't able to find an html viewer.
nupurs
@rabeluk
It could be because you are using and unsupported OS.
You might want to try on one of teh supported OS given on page 24 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug973-vivado-release-notes-install-license.pdf
Nupur
