Visitor xiaodark
Vivado installation failure
I am trying to install Vivado 2019 on Deepin(one kind of Ubuntu) pro 64 bits but when I run xsetup I have an error loading installation data.
The xinstall log file :
2019-09-26 11:55:51,844 INFO : com.xilinx.installer.api.e:? - Log file location - /root/.Xilinx/xinstall/xinstall_1569470129936.log
2019-09-26 11:55:51,867 DEBUG: com.xilinx.installer.api.e:? - Memory usage -- Used memory: 4482 MB. Total memory: 7875 MB
Recent cpu usage for system: 23%
2019-09-26 11:55:51,874 WARN : com.xilinx.installer.utils.o:? - Could not load native code
java.lang.UnsatisfiedLinkError: /media/laji/F28696C5869689AD/vivado/vivado2019/Xilinx_SDx_2019.1_0524_1430/lib/lnx64.o/librdi_install.so: /media/laji/F28696C5869689AD/vivado/vivado2019/Xilinx_SDx_2019.1_0524_1430/lib/lnx64.o/Default/libstdc++.so.6: 文件过短
at java.base/java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.base/java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.base/java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.base/java.lang.Runtime.loadLibrary0(Unknown Source)
at java.base/java.lang.System.loadLibrary(Unknown Source)
at com.xilinx.installer.utils.o.d(Unknown Source)
at com.xilinx.installer.utils.o.a(Unknown Source)
at com.xilinx.installer.api.e.<init>(Unknown Source)
at com.xilinx.installer.api.d.<init>(Unknown Source)
at com.xilinx.installer.api.a.a(Unknown Source)
at com.xilinx.installer.gui.InstallerGUI.<init>(Unknown Source)
at com.xilinx.installer.gui.InstallerGUI.<clinit>(Unknown Source)
at com.xilinx.installer.api.InstallerLauncher.main(Unknown Source)
2019-09-26 11:55:51,878 FATAL: com.xilinx.installer.api.e:? - Could load native code!
com.xilinx.installer.utils.o$a: Unable to load native libs.
2019-09-26 11:55:51,880 ERROR: com.xilinx.installer.gui.InstallerGUI:? - Error instantiating InstallerAPI!.
com.xilinx.installer.utils.k: Error loading native libs
Caused by: com.xilinx.installer.utils.o$a: Unable to load native libs.
... 6 more
Would anyone be able to point me in the right direction to solve this problem.
XiaoDark
Re: Vivado installation failure
Looks like unsupported Operating System.
The supported Ubuntu of 2019.1 is Ubuntu Linux 16.04.5, 18.04.1 LTS (64-bit)
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
-vivian
Visitor xiaodark
Thank you. I will try again in the new system.
