clmnt_lbrr
Vivado internal error when using block design
I am on  a Ubuntu 14.04.3 64 bits laptop, when I try to use block design either with tcl script or with a new project > create block design, I have the following error :
[Vivado 12-106] *** Exception: java.lang.NumberFormatException: For input string: "0,01"
If any one can help to solve the problem that would be appreciate.
clmnt_lbrr
ashishd
Hello @clmnt_lbrr,
Check if this helps
http://www.xilinx.com/support/answers/51331.html
Ashish
ashishd
Hello @clmnt_lbrr,
Check if this helps
Ashish
clmnt_lbrr
Hi @ashishd,
Thanks for the quick answer. Do you know in which file should I do the trick? it's not exactly specified in the AR#51331
Clmnt_lbrr
vemulad
Hi @clmnt_lbrr
You can change the system language to English.
or try the workaround mentioned in the last post of the below thread
https://forums.xilinx.com/t5/Design-Entry/Connection-Automation-failed-with-a-simple-MicroBlaze-design/m-p/595464
Deepika.
Deepika.
clmnt_lbrr
Thanks both of you for your good advice!
For future people in the same case, I added the lines in the AR#51331 directly at the end of the file seupEnv.sh located in <INSTALL_LOCATION>/Vivado/2014.1/bin/
