salmankhalid29
Vivado licences for ARTY-7 Evaluation Kit
Hi Guys
I bought a Artix-7 35T Evaluation Kit to learn more about FPGAs. The reason I chose ARTY was that it came with a Vivado Design Suite, Design Edition. Unfortunately I have not be able to download it as it gives a export compliance error when I try to download it. I have the voucher for ARTY node locked, device locked license. Could someone please help!!!. I am currently in Pakistan.
Salman
salmankhalid29
I know this subject has been discussed many times however every time the support was given by someone in the company and I am looking for that as I am not able to contact XILINX directly.
prathikm
Hi @salmankhalid29,
Did you check this AR#44043? :https://www.xilinx.com/support/answers/44043.html and this forum post: https://forums.xilinx.com/t5/Welcome-Join/Export-compliance-verification-error/td-p/717824.
If the above suggestions don't help, you will need to create a Service Request to verify your Export Compliance Status at https://www.xilinx.com/support/service-portal.html.
Thanks & Regards,
Prathik
Helpful answer -> Give Kudos
msalmankhalid
Hi Prathikm
I have tried the procedure mentioned in https://forums.xilinx.com/t5/Welcome-Join/Export-compliance-verification-error/td-p/717824 . However I was not successful. Also I cannot open a service request due the same reason of export compliance error. I was given a node locked device locked license for Arty-7 35T when I purchased it however they are not allowing me to download the software for which the license is given. I was not informed about that when I purchased it and it is useless without the hardware. Also the Arty-7 is a entry level FPGA for beginners I don't understand....
Best Regards
Salman
msalmankhalid
correction * useless without the software
Also if there is alternative software which I can use with Arty-7 please let me know.
prathikm
Hi @msalmankhalid,
We apologize for the inconvenience caused to you. Can you please check your personal message inbox so that we can help you create a Service Request ?
Thanks & Regards,
Prathik
