ChrisHaddad
Vivado not downloading
I am not being able to download Vivado. I am entering all of my correct information but a message pops up stating that there is an error and I have some wrong info entered. If someone could help me I would greatly appreciate it.
Thank you!
Regards.
ansarimo
Hi @ChrisHaddad
In relation to this error, unfortunately, due to strict internal export control policy, it is no longer possible to maintain an online account in some E or D category countries.
Please go through the below link and check if your country is on the E and/or D list, as this could be one of the reasons you are seeing this error.
https://www.bis.doc.gov/index.php/documents/regulation-docs/2255-supplement-no-1-to-part-740-country-groups-1/file
The Answer Record in the error message also explains this situation: https://www.xilinx.com/support/answers/44043.html
Hope this helps.
Thanks and Best Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
ansarimo
Hi @ChrisHaddad
Are you getting an error somewhat similar to the below snapshot?
From which country are you trying to register/download?
Have you checked this Answer Record in relation to the Failed export compliance issue?
please send an email to Xilinx Customer Support (websupport@xilinx.comindicating your "export compliance" issue and they in turn will contact Xilinx Global Trade Compliance team on your behalf, who would be able to screen and verify your profile and if all is good, re-activate this then, so that you can then login and download the required software without issues.
Hope this helps.
Thanks and Regards,
Ansari Hunen
ChrisHaddad
Hello Sir,
Yes, this is the exact error I am receiving. I am residing in Lebanon. Does my country affect my ability to download the IDE?
Thank you for your help and support.
Chris.
ansarimo
Hi @ChrisHaddad
Hope this helps.
Ansari Hunen
