Vivado or ISE WebPACK for students
Hi!
We are conducting a contest for students (aged approx. 16-19) to learn how to design ASICs and use FPGAs in Austria (http://www.invent-a-chip.at/). The students will use the WebPACK software by Xilinx during the workshop in November and afterwards at home when they are working on their projects.
For tests we are using mostly Spartan 3AN boards. Now I found that the new Vivado only supports series 7 FPGAs (Artix, Kintex, Zynq) but no "younger" ones.
Is it therefore better that we teach the usage of the (now somewhat outdated) ISE Design Suite?
  Hansi
Re: Vivado or ISE WebPACK for students
I would recommend you to make them familiar with Vivado Design Suite than ISE because ISE is currently is maintenance mode (no further advancements will take place). But for basic concepts understanding, you can still refer some good ISE documents for e.g. to understand timing basics, you can still use UG612.
Ashish
At the age of 16-19, I think should be fine to get a feel of how FPGA flow works. If you are doing this as a part of University program you may contact xup@xilinx.com for additional help.
Thanks,Vijay
Oh, I saw that Vivado only supports series 7 FPGAs and no older ones, even with the most expensive licenses. Google found some discussions dating 1-2 years back about people asking for support of series 6 FPGAs, but to no avail.
Further, the discussions asked to expicitely state this fact at the Vivado site, and a Xilinx employee said he will tell the marketing department to do so. But the opposite was done, now it is even less clear that Vivado doesn't support older FPGAs. May I here again ask to state that clearly on the Vivado product page?
Although I like the integrated design and the TCL based flow, we can't use Vivado for our students, because none of them will have this new evaluation boards, even not here at the university.
Bye
   Hansi
Vivado doesn't support any devices older to 7 series.
Check page 15 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf which clearly shows the devices supported.
Thanks,Vijay
Hi!
Yes, that is where I found that after an hour of searching. My question was to add that clear statement directly at the Vivado main website. With the same clarity as the supported devices are mentioned on the ISE main website.
  Hansi
So Vivado only supports the 7-series FPGAs and not the older FPGAs.  ISE supports older FPGAs such as Spartan-3 and -6.  However, it seems like you will no longer support ISE.  Does this means that Xilinx no longer supports Spartan FPGAs?  If that is the case, then perhaps I should be looking at Altera, rather than Xilinx.
Hi @dpollum238
We do support customers using ISE tool, provide workarounds for issues seen.
But there are no further ISE releases. Only critical bugs will be fixed in ISE.
Deepika.
Deepika.
