Observer srikanth1986
Vivado vs SDAccel license
I see license purchase option for Vivado as well as SDAccel and both cost the same. Considering that SDAccel uses Vivado in the background, can one use both the tools with just the SDAccel license or do I need to purchase both the licenses?
Re: Vivado vs SDAccel license
@srikanth1986
Just purchase SDAccel license. It will give you the features needed to run Vivado as well.
Nupur
@srikanth1986
Nupur
@nupurs wrote:
@srikanth1986
Just to be 100% clear, I can do RTL/HLS development using Vivado/Vivado HLS  right through bitstream generation using the SDAccel license?
Hi @srikanth1986,
Yes, you will be able to run all the features in Vivado or Vivado HLS.
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
