We cannot fulfill your request as your account has failed export compliance verification.
I'm having problems to download software.
"Please correct the errors and send your information again.
We cannot fulfill your request as your account has failed export compliance verification."
I need help
Re: We cannot fulfill your request as your account has failed export compliance verification.
Hello @laurarojas252801 ,
Thanks for letting us know. Please note that your account was previously blocked and has been screened by our export compliance team and was placed on hold and that is the reason why you were previously unable to generate a license or download Vivado.
However, export compliance team has now reviewed your account and has enabled your profile and you are good to go now. Please try again and let me know if you still seeing this error.
As a recommendation, since your profile was blocked in the first place, there is a chance that each time when you update your Xilinx.com profile in the future, it will get blocked once again. Therefore, please don’t update your profile (unless it is needed to do so) once the profile is re-enabled.
If this happens for you again, please contact Xilinx Customer Support (websupport@xilinx.com) (see AR https://www.xilinx.com/support/answers/44043.html for more details) and we will unblock your profile again then.
Apologies for any inconvenience caused.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
